ZRX SPARK PLUGS
ZRX SPARK PLUGS
how do you get the 2 centre spark plugs out of a ZRX, the frame and wiring are in the way , and the plug cap is too long to remove, any tips before i remove the wiring.
- paul doran
no 2+ 3 can be a little difficult to get out just spray some wd40 around the caps + they will come out easily. no need to remove the coils if you have a decent set of tools just a 3/8 long extension + knuckle joint make sure the caps are pushed right down when re assembling they have a tendency to collect water + the water boils like a kettle + blows the plug cap of the spark plug + you end up with a misfire or only running on three cylinders. look into the core of the cap to make sure it has no corrosion
