indicators
paulmceleney
- Chunks
indicators
indicator bulbs keep blowing only the rear its never both sometimes it the left and then other times it be the right but always one will not be working when i get back home from a ride out
paulmceleney
- Chunks
paulmceleney
- Chunks
paulmceleney
- Chunks
i dont think o rings would have sufficient damping. the problem with the mini indicators is you are limited with how thick your damper rubbers can be as there is not that much thread on the indicator so this limits the thickness of the rubber. really you need at least 3-4 mm either side of the indicator mounting bracket. could you not rubber mount the mounting bracket instead of the indicator? are the indicator flashing at the correct rate? + are they excessively bright ? check your charging system for overcharging. you can also buy a indicator regulator from e bay specially designed for mini indicators which you can adjust the voltage
paulmceleney
- Chunks
I think its down to vibration since its only the rear that I was having problems with. I tried to rubber mount the bracket first but had nothing suitable in my shed at the time .so I had box of o rings and selected the one that was tight on the thread they are about 4mm in thickness but a bit less when crushed 2mm. I have done about 50 miles so far on country roads and everything is fine ,as before less than 5 miles a bulb would of blown.
Also you cannot notice the o rings which looks better but if It fails I will have to change the way I have done this but all good so far thanks paul
