bloody indicators
bloody indicators
got a rebuild of a 900 a4 ongoing, got a new loom today so stated fitting it with new switch gear and ind relay, got power to idiot light cluster,main beam/flash and oil lights work ok, fitted the indicators on one side but no joy using green or grey wires. no light at winker front or back. checked that the earth on the switch to bars was touching, even ran an earth from the switch to the battery but still nothing. got to be something simple thats wrong. any suggestions?
wayne
wayne
- steve bowdler
- z1000puddin
have you got power to the green + grey indicator wires? when indicator is on . if you have run a wire from the indicator stem to a good earth. check the brown wire on the indicator relay should be live when the ignition is on. have you got the earth leads attached to the indicators /black wires with yellow trace. have you checked the bulbs
tried fitting all 4 indicators, no luck, opened the switch again, ignition on
, no power to the orange wire, pulled the block connectors apart, no power to either side of the orange wire, power at the orange side of the ind relay, tried the orange wire at the hazard switch plug, got power there. plugged the hazard switch in, all 4 illuminated but not flashing
z1bman wrote:if you have power at the orange wire that is connected to the relay you must have a break or bad connection on the orange wire. run a wire from where the orange fits on the relay + connect it to the orange in the switch
ran a wire as suggested and indicators light up but not flash, pulled and reconnected all wires i could see in case of a bad connection, as there was no indicators when i got the bike i dont know if there may be anything i am missing, there is a two pin orange and brown wires at the head of the loom inside the headlight shell with nothing i can see to plug into, should there be ?
yes that is for the indicator bleeper it doesn't have to be connected. did you disconnect the orange wire from the relay + attach the wire on to the relay terminal + then to the orange in the switch? if you have done this? your relay is faulty. also disconnect the orange from the relay + connect to the + side of the battery if the indicator comes on but does not flash your relay is at fault .if the indicator does not come on your orange wire is broken
just make sure that the spade connector on the orange wire is a good connection where it is crimped sometimes the wire is not crimped. only the outer sheathing. normally that wire has no joint it is a continuous piece of wire from the relay to the block connector under the tank but the z900a4 has hazards + the orange wires could possibly be crimped together in the harness + that is where it could be broken
