Z1100r barrel swap help
weaver
#1 PostAuthor: weaver » Wed Apr 17, 2013 2:17 pm
My barrels have quite a few damaged fins so I bought what I was told were z1100r barrels.My plan was to sweat out the liners from my damaged barrels and fit them into the undamaged replacements.
However on stripping the bike there are some differences between the 2 sets of barrels.
Both barrels are stamped 1089 cc and measure 72.5mm.
However if you check the pics you will see on the originals still on the bike there are no recesses for seals on the 4 outer studs,whereas on the replacements there are.
Looking at the fiches it looks like the barrels I have bought are from a Gpz1100b1/b2.
My questions are,can I still sweat out my barrels and fit them into the b1 barrels,will I need to use the b1 head gaskets?Will my z1100r head fit with these barrels?Any other problems I haven't thought of?
thanks
#2 PostAuthor: z1bman » Wed Apr 17, 2013 4:31 pm
YOU WILL NEED HEAD GASKETS 11004-1263
HEAD O RINGS 92055-1148
YES THE LINERS ARE INTERCHANGEABLE BUT YOU WILL POSSIBLY HAVE TO GET THEM SKIMMED
big green bus
#3 PostAuthor: big green bus » Wed Apr 17, 2013 8:14 pm
I would just get the fins repaired you might get more problems by disturbing the liners. I got some barrels sorted by cutting fins off a goosed set and having them welded onto my good set.
weaver
#4 PostAuthor: weaver » Fri Apr 19, 2013 11:00 am
z1bman wrote:YOU WILL NEED HEAD GASKETS 11004-1263
thats what I was thinking mate,will order them today
#5 PostAuthor: z1bman » Fri Apr 19, 2013 11:26 am
weaver i have noticed that your replacement barrels have the split spring dowels where the 4 o rings fit . make sure they are inserted slightly above the o rings when you re assemble the head. they are there to protect the o rings from excessive oil pressure + to stop the oil from distorting the o rings + causing oil leakage
Mr Puffin
#6 PostAuthor: Mr Puffin » Fri Apr 19, 2013 12:03 pm
I would agree with Big Green Bus, as there is the possibility of distortion also if a liner does not fit back in exactly the same direction, the cylinder piston wear would no longer match :| Repaing the fins is not difficult or expensive :wink:
weaver
#7 PostAuthor: weaver » Fri Apr 19, 2013 3:47 pm
z1bman wrote:weaver i have noticed that your replacement barrels have the split spring dowels where the 4 o rings fit . make sure they are inserted slightly above the o rings when you re assemble the head. they are there to protect the o rings from excessive oil pressure + to stop the oil from distorting the o rings + causing oil leakage
thanks for the tip mate,I ran a straight edge over the top of barrels and two of the inserts were slightly proud of the mating surface so I tapped them flush,I will see what they are like with the seals fitted,ordered from zpower today so should be here in a couple of days
weaver
#8 PostAuthor: weaver » Wed Apr 24, 2013 4:10 pm
sweated the liners out and swapped them over,a couple were slightly proud so had the top of the block skimmed :)
