Harris Magnum 1
#211 PostAuthor: Ginger Bear » Sun Apr 14, 2013 4:32 pm
Piggy,
I used to use a professional product, that was called something like slip ease, but Googling it brings up all sorts. :shock: :shock:
I still have some on the shelf if you'd like some?
Whilst searching I found this guide that might be useful... http://www.socalcustoms.com/Shop//vinyl ... ctions.pdf
# 104
steve bowdler
#212 PostAuthor: steve bowdler » Sun Apr 14, 2013 5:50 pm
I had some done by professionals and they use the johnsons baby products.[/quote]
Last time I used Pros they also used baby products :lol: :lol:
#213 PostAuthor: Pigford » Sun Apr 14, 2013 6:03 pm
steve bowdler wrote:I had some done by professionals and they use the johnsons baby products.
Last time I used Pros they also used baby products :lol: :lol:[/quote]
I'm not paying those sort of prices :?? I always thought it'd just end up in a big sticky mess :!:
#214 PostAuthor: Ginger Bear » Sun Apr 14, 2013 6:07 pm
Cue Jimmock......... :roll:
# 104
#215 PostAuthor: Pigford » Sun Apr 14, 2013 6:58 pm
Cheers for the download instructions Bear :wink:
#216 PostAuthor: Pigford » Tue Apr 16, 2013 11:33 am
Here we go................ TAKE A BOW BIG FLUFF :wink:
As the decals were quite small (subtle) I just whacked them on dry - no fear :twisted:
I did think about running another HARRIS decal along the top/back of the seat unit - but decided to keep it real simples :!:
brian 450
#217 PostAuthor: brian 450 » Tue Apr 16, 2013 12:16 pm
Looking good mate
PETER KZ1A
#218 PostAuthor: PETER KZ1A » Mon Mar 10, 2014 3:44 pm
looks fakkin good,anymore progress?
#219 PostAuthor: Pigford » Mon Mar 10, 2014 6:12 pm
Hi Peter, YES... its in "Kings Lineage" section...... :wink:
http://www.z1ownersclub.co.uk/forum/vie ... 90&start=0
Padders
#220 PostAuthor: Padders » Mon Mar 10, 2014 6:27 pm
Looks great Mark
PUM 13
Is Vic There
#221 PostAuthor: Is Vic There » Mon Mar 10, 2014 7:55 pm
nice brakes :D
#222 PostAuthor: Ginger Bear » Tue Mar 11, 2014 9:03 pm
And two of 'em as well..............
.............. Not normal 'Piggy spec'. :shock:
# 104
#223 PostAuthor: Al » Tue Mar 11, 2014 9:21 pm
This particular picture;
Absolute animal. :twisted:
#224 PostAuthor: Pigford » Wed Mar 12, 2014 8:42 am
Thanx for the kind comments chaps :wink: As it nears completion, I'm starting to get nervous :!:
Just a bit more wiring to finish off then I can try the motor out. Also need to bleed the rear brake as it was bone dry and needs a bit more fettling to get all the air out.
Its got a 1978 Z1R lump and has be sat idle for several years - probably just a standard motor?. I do NOT know how it runs (if at all) but I've had the sump off to clean the oil pump gauze (not too mucky) and also set the valve clearances (which were pretty good - just a couple needed doing). The compression seems real good so hopefully she'll be okay :|
Another point which can only be checked on the hoof - the rear shock was rebuilt and due to that JMC (still not sure about it) I had to get a beefier spring - which may prove a bit stiff???? I've lost a couple of stone since the build started too. One good thing is a new spring is only £35.
The kickstart is pretty useless as it hits the rearsets, so it will need a decent battery :evil:
As for registering it, that will be a laff :shock: But there is a temporary "PLAN B" - I'll run her on a spare Z900 V5 which came with the project :lol:
Padders
#225 PostAuthor: Padders » Wed Mar 12, 2014 9:19 am
Target date Blackpool we can have a Z1OC Harris Magnum section :lol:
PUM 13
Users browsing this forum: Bing [Bot] and 8 guests
