generator noise
johnA
generator noise
#1 PostAuthor: johnA » Sun Mar 31, 2013 6:38 pm
hello gents i removed the generator cover from my gpz1100 A1 to paint it. i put it back on today put the oil back in it started fine but every so often a rattling noise will come from that area has anyone got any ideas what i could have done wrong.it seemed to go back on ok.
many thanks in advance john
#2 PostAuthor: Pigford » Sun Mar 31, 2013 6:41 pm
Get the cover off & check all rotor bolts - back of it where the starter roller gear stuff is :!: :!: :!: :!: :!: :!:
#3 PostAuthor: Al » Sun Mar 31, 2013 10:46 pm
Did you remove the stator wire holding clip?
If so did it go back in with the bottom end of it tucked behind the two little cast bosses on the casing?
If not it will rub the outside of the stator and make a rubbing or tinkling sound.
You'll see it if you take it off again as it will have a shiny mark on the rotor's outer casing.
Taffus
#4 PostAuthor: Taffus » Sun Mar 31, 2013 11:56 pm
zorded wrote:Did you remove the stator wire holding clip?
Yep, Al (Zorded) sorted mine out this way :oops:
(\__/)
(")_(")Image
johnA
#5 PostAuthor: johnA » Mon Apr 01, 2013 12:18 pm
Thanks for the replies gents it only makes the noise intermittently.
Many thanks John
