Z1000 Shaft Coils
st coils
there mounted under the rail not above
THE ORIGINAL TARMAC TERRORIST
Z1OC # 886
Z1OC # 886
Rich wrote:one of them also looks to be a suzuki coil
You could well be right there Rich
I do apologise Nige , i've given you bum information regarding bolt centres .
Just measured coil mounting brackets on the frame and they're 40mm between centres .
I see what you mean now that the coils must resemble a brockwurst as there is only 60mm across the framr to fit the two coils into .
In my defence the coils came in a big box with loads of ST bits
Please disregard four previous posts worth of nonsense
0172 . Geoff Parr
nigel bessant
nigel bessant
