I bought the Z1000 G1 or Z1 Classic Fuel Injection from DK the other week.
I know it's a long shot but worth an ask .
I am after a cylinder head,
1015 block,
Tank,
LH side cover
chrome plated alternator cover and sprocket cover,
high bars ,
clutch lever holder (perch)
4 into 2 exhaust.
I have not pulled down the top end yet but it has freed off with a drop of diesel down the plug holes and kicks over freely now.I know most of you would just throw away the injection system and fit carbs and it may come to that but I thought I would give it a go first as it is quite a rare beast as they only did two or three thousand of them. Any one out there that has or has had 1000 h or G1 please let me know how you went on.
If I get it on the road it will give the Z1R riders something to take the pi** out of .
Ta
Roger Hill
Wanted Z1000 G1 Parts
post
Wrong there matey .Its a bike I would have so I wont be takin the urine out of you ,good luck with the resto and lets see some piccys.
Ted
Ted
"Work this is why I did it"
"I've had more minutes than I have left"
Z1R D1
Granada
vantastic Transit........
KLE650
Z1R D1
Granada
KLE650
Here is the beast .I saw it and thought that it might make a project and if not it was not a bad selection of parts. I was out when the auction ended and was surprised that I had won it for with my first bid as I had bid a tad more. I know some of the guys on here may have had snags with DK but I can only speak as I find .They were very professional I picked it up less than 18 hours after the close of the auction and it was ready for me when I got there with all the paperwork sorted.They were really helpful .Further to this they had found the original American reg doc and gave it me along with the phone number of a great guy called Geoff from down south who had left his number with them as he has G1 and a few parts . Geoff has very generously sent me bound copies of the Injection manual and the workshop manual supplement for the bike .The bike is in quite good condition apart from the damaged parts and has unseized after a drop of diesel was put down the plug holes. As a further bonus It came with a genuine key fob and an oil cooler kit.So I will try to get it sorted .I was quite amazed to find that the injection system is very similar to the Bosch Ltronic system used on the old BMW K100 motors.
http://www.ebay.co.uk/itm/350729178543; ... 26_rdc%3D1
- z1000puddin
First up
apologies to Taffus,tlc and GB I appear to have hi jacked my
own thread if you guys think it should be moved that's fine .
I worked on BMW's from the early 1970s until last year and have always thought that they used this system first on a bike but I was wrong .The K100's did not arrive until 1883. Kawasaki used it on the Z1000H and the KZ/Z1000 G1 Z1 Classic Fuel Injection in 1980.The two systems are virtually identical in operation .The Kawasaki uses Mikuni throttle bank made in Japan the BMW uses ones made by Bing in Germany.The Kawasaki system must be in conjunction with Bosch as it is so similar that Bosch would have not been very happy .The only difference is that the Bosch/BMW uses a water temp sensor in the block .The Kawasaki uses a head temp sensor .The Bosch /BMW system is an old car system from the 1970's that uses a paddle in the back of the air box that has a potentiometer attached to it and as the engine sucks more air in so the paddle is pulled further round this measurement is the main thing that is used to adjust the injection duration the other variables being air temp,block temp,altitude/air density and throttle body position.There are a few other odds and ends as well like a signal supplied by the ignition module this was call the TD signal on the Bosch/BMW system and told the Injection E.C.U what speed the engine was turning.There is a timer circuit to control the fuel pump so that it stops pumping if there is no TD signal i.e.. the engine has stopped and does not need fuel.
Evening Hobbo I have got that set of Z1R carbs I had from you as plan B if the injection is past it .
Me and the better half had "One of those years"with a few health issues and a few losses as well in the family but are getting sorted now.
I am hoping to have some quality time out on the bikes this summer (if we have one )
Puddin
I will measure the height /width of the bars and let you know.
Ta to everyone who has contacted me.
Puddin
Users browsing this forum: No registered users and 1 guest
