My Z1000A2A
Surfdeneige
My Z1000A2A
#1 PostAuthor: Surfdeneige » Mon Aug 20, 2007 9:43 pm
Bought it in March and drove 400 faultless miles through very high winds, rain and even snow. Got it home, washed it, took the tank and panels off to have a good look at it, stuck it in the garage and didn't touch it for 3 weeks or so as it was snowing pretty much all the time. First chance I got I wheeled it out of the garage and it was running really badly. Suspected a dodgy plug as no.3 wasn't that hot. Still running badly. Took off a float bowl and a fair bit of muck. Stripped carbs and rebuilt, still running badly, worse in some ways. Got a new coil, no difference, swapped coils, no difference. Got a whole new set of plugs, no difference. Checked everything I could and it all seemed okay. Bought another set of carbs but didn't fit them.
Finally bit the bullet and stuck it in the local kawa guru mechanics shop last week.
He phoned me twice to say he was struggling and suspected valves or rings due to smoke. He phoned the next day to tell me he had cracked it and the bike was fixed bar a fek'd battery. Stuck a new battery in it today and took it for a wee spin. Yeeha, I have the z back.
So what was it?
A ken fit like!
#2 PostAuthor: chrisNI » Mon Aug 20, 2007 11:37 pm
I give up... do tell.
london calling
#3 PostAuthor: london calling » Tue Aug 21, 2007 5:23 am
It wasn't the rings or valves as the guru thought :?:
Jack
uk kev
#4 PostAuthor: uk kev » Tue Aug 21, 2007 6:44 am
So if it wasn't carb related I guess it has to be electrical, so condensors maybe?, bad earth, or regulator.
#5 PostAuthor: Pigford » Tue Aug 21, 2007 9:30 am
Errrrrrrrrrrrrrrm, was it badly adjusted mirrors :?: :|
ollie
#6 PostAuthor: ollie » Tue Aug 21, 2007 9:37 am
errr no fuel !!!!!!! or plugs sparking around the electrode
Muddychris
#7 PostAuthor: Muddychris » Tue Aug 21, 2007 10:01 am
Problems with the stop/run switch?
Chris
Davy Doherty
#8 PostAuthor: Davy Doherty » Tue Aug 21, 2007 4:53 pm
Nackered battery!!!
Life's too short!
Steve S
#9 PostAuthor: Steve S » Tue Aug 21, 2007 5:23 pm
Tyre pressures low!!
#10 PostAuthor: Pigford » Tue Aug 21, 2007 6:41 pm
Front tyre pressure low, rear too high :?:
Surfdeneige
#11 PostAuthor: Surfdeneige » Tue Aug 21, 2007 9:12 pm
Fuel leaking through the carbs filling the crank cases with petrol. Very common apparently. Don't leave it on prime for more than a few seconds.
A ken fit like!
Big John
#12 PostAuthor: Big John » Tue Aug 21, 2007 9:38 pm
Forgot to switch the petrol tap off on the LC the other day and when I took the exhausts off to fit the Allspeeds the right hand exhaust was full of fuel.
86 Z1100R x 2, z7/11r, ZRX400, Z1000B2, ,ZRX1100C4 & Z1000J3.
#13 PostAuthor: Pigford » Wed Aug 22, 2007 8:55 pm
Took the tank off me bike tonight, put it in garage whilst fixing bike. Missus kept hassling me to walk dog, so packed everything away quickly ay 9pm, took doggy out (& the missus).
Came back to a house stinking of petrol :shock:
Must have knocked fuel tap when moving it to shut garage up, and a good 2 pints on garage floor :oops: Thats over a quids worth :shock: :?
#14 PostAuthor: Rich » Thu Aug 23, 2007 6:39 pm
You'd better put a proper tap on that it should have emptied it :D
#15 PostAuthor: Pigford » Thu Aug 23, 2007 6:53 pm
Rich, its a twin outlet Pingel, but luckily, it was only moved a little bit, or it would have been a whole FULL tankful on the floor :| as I'd just come back from the garage :!:
