Anybody know of a company where I can purchase some `short length` throttle and clutch cables for a Z1000 A1?....I'm running drag bars so need shorter than standard.
Also, due to the fact that my drag style `club foot` swing arm is way longer than standard but I am running a standard Z1000 rear brake cylinder assembly and calliper setup does anyone know of somewhere that would make, or I can buy, a longer length of brake hose to suit?
Cheers, Paul
Short throttle and clutch cables & longer rear brake hose.
- Paul Whitehouse
If it's too loud....too bad.
- Paul Whitehouse
Demon Tweeks have a 'build a line' service although im sure they buy direct off Goodridge.
Hose available in clear, carboline and black colour coating.
Fittings - Stainless or Black Stainless.
Hose length in clear (ie 425mm long) listed as SB0425CL available in 25mm increments. You'd also require the Banjo Adapters either end
Straight - SBK592-03C
20* -SBK593-03C
45* - SBK594-03C
20* side banjo adapter - SBK597-03C
+ Banjos and copper washers
Direct order tel - 01978 664474
Taken from one of there catalogues (no prices tho')
Hope this helps
20* -SBK593-03C
45* - SBK594-03C
Hope this helps
Wots up DOHC
- Paul Whitehouse
- Paul Whitehouse
This of any use to you, taken from Venhills site -
http://www.venhill.co.uk/Hoses_-_Compon ... RHOSE_PLUS
Wots up DOHC
