Had the tank off today to set the valve shims, noticed both coils are trying to divide in half. Though not ideal the bike still runs OK, did have a issue with it cutting out while sat in traffic on a very hot day. Do you think it is coil related as both would have to go down at the same time. The bike has electronic ignition and I was suspecting this to be the problem.Any help would be much appreciated
If as I suspect that the coil's have seen better days has any one got a pair they would like to sell
Thanks Stuart
