pressing out cylinder liners
My Lawson rep has damaged cylinder fins,I believe the bike has a big bore kit fitted and I have obtained an undamaged set of barrels on std bore.
I am thinking of pressing the liners out of the barrels with undamaged fins and fitting my rebored liners in.I have access to a press,has anyone done this and if so what was your experience? I saw an article in Practical Sportsbike mag recently where they did this I think with out a press..
thanks
thanks
I have done this myself, it's relatively easy heat up the block with a blow torch whilst supported either side of the liner you want out and use a piece of hardwood on the bottom of the sleeve and a copper mallet on the wood tap firmly and when hot enough the liners will tap out make sure you have a piece of ply or hardboard underneath if you are doing it on the floor so if the liner pops out quick it does not get damaged also remember which is front and back, same method for putting back in be patient and don't beat the hell out of it. Alternatively if you have access to a press use it, you may also have to get the surface milled when put in the new block.
They were cold pressed in at the factory but you must warm them up to remove or they will drag alloy block material out with them and cause a loose fit.
No need to use a press.
Put the block under the grill or in the oven sitting on the liners and slowly increase the heat.
When they are hot enough you will hear a clunk as the block slides down the liners on to the oven shelf.
Quickly remove the liners and replace with the good ones which you obviously removed first by the same method.
Have something ready to set the block on that will allow the liners to hang free.
You need something weighty (four bricks etc) to sit on the liner tops to keep them seated while they cool.
When they are cool you can check they are fully seated with your press.
The barrel might need a light skim to level the liner tops.
I would not recommend reboring the liners prior to this as swapping the blocks might alter the piston clearances.
You will need to recheck piston/bore clearances and rehone if necessary.
