Jersey J
phil le brocq
#16 PostAuthor: phil le brocq » Tue Feb 19, 2013 6:09 pm
Wow, a pretty comprehensive answer, thanks for that. I think I'll follow your gearing, if you reach 120mph in Jersey you can run out of a lot more than Puff! I'm on a similar ratio on the CBX, I ran out a quater mile sprint at the red line in 4th at about 110......Enough for me. I presume I don't need to off set as I'm using the GPZ wheel?
Thanks again Phil
#17 PostAuthor: Al » Tue Feb 19, 2013 6:59 pm
Offset front is down to tyre width. I have a 130 tyre pinched onto a rear 2.50J rim.
My Gpz front sprocket is dished as in 3/8 off set i guess. The 530 chain misses the 130 tyre by about 7 -10mm.
The Talon rear i bought is double sided. It can fit either way round to give you about 6 or so mm or variation between the two orientations.
Very handy for me as my sprockets dont line up as in staggered. Probably bent somewhere!!
Going back to gearing for a second. when i said it runs out of puff at 115 to 120 mph i mean at 11,000 RPM.
If you only like to rev to 9,500 youre looking at just into treble figures.
Spoke to Ray Debben about this the other day and its refusal to yang properly and he said give it 12!!
:shock: :shock: :shock:
phil le brocq
#18 PostAuthor: phil le brocq » Tue Feb 19, 2013 9:41 pm
Thanks again for the gearing, I'm not sure where we are as regards offset, I'm running a 140/80/18 BT45 on the back but I think everything should still be in line as it's all comparible Kawasaki. I think the best thing is give them a ring and see what they say unless you have a..... FINAL ANSWER......
Phil
#19 PostAuthor: Al » Wed Feb 20, 2013 8:32 pm
Phil it may come down to availability although there are other sprockets (other models with the same spline pattern). Talon do off-set fronts periodically but may not have any in stock. Others may have.
If you had a standard J sprocket and the 630 chain missed the tyre you should be ok with a standard 530... perhaps.
tlc
International Rep
#20 PostAuthor: tlc » Wed Feb 20, 2013 8:56 pm
Lovely J Phil.
Have you tilted up the tailpiece somewhat? Looks good whatever.
Asphalt Cowboy
phil le brocq
#21 PostAuthor: phil le brocq » Wed Feb 20, 2013 9:24 pm
Yes to the tail box, about twenty five years ago I junked the the rear mudgaurd, lifted the tail light on a couple of brackets and screwed the tail box straight to the seat, always loved the look and have never changed it back.
Phil.
phil le brocq
#22 PostAuthor: phil le brocq » Sat Mar 02, 2013 6:02 pm
YEE......####ING.....HAA!......... she's a runner! :D :D :D couple of minor issues, but shit! is that pipe awsome or what. Not convinced I'm still on the neighbours Christmas card list...Loud as and I couldn't bring myself to fit the baffle. :lol:
#23 PostAuthor: Al » Mon Mar 04, 2013 6:37 pm
:D
phil le brocq
#24 PostAuthor: phil le brocq » Mon Mar 04, 2013 10:22 pm
While I'm on, thanks Al for all your advise regards chains and gearing, I'm all sorted thanks to B&C who also sorted Nick Allison's Moriwaki. I gave them the numbers you gave me and nothing seemed to be to much trouble, All done in a few emails. Once again many thanks.
Phil. :)
phil le brocq
#25 PostAuthor: phil le brocq » Sat Mar 23, 2013 6:20 pm
Thanks to all and B&C in particular , 530 conversion is now fitted and I thought I'd better paint the headers blue for effect :D. I suppose I'd better order the brake parts and find out if it all works!
[img][img]http://i1358.photobucket.com/albums/q769/bbrocq/002_zps18c53b0c.jpg[/img]
Phil[/img][img][img]http://i1358.photobucket.com/albums/q769/bbrocq/001_zps6f98c41e.jpg[/img][/img]
#26 PostAuthor: Pigford » Sat Mar 23, 2013 6:54 pm
Phwaaaarrrrrrrrrr :twisted:
#27 PostAuthor: Ginger Bear » Sun Mar 24, 2013 9:21 am
Come on Phil....... Lets have a look at the 'other' side. :sou
# 104
saxon46
#28 PostAuthor: saxon46 » Sun Mar 24, 2013 11:17 am
loving the moriwaki points cover..............are they still available.....love to get one for mine.........
mark ......english lad in wales....where men are men and sheep are scared !!!!!
phil le brocq
#29 PostAuthor: phil le brocq » Sun Mar 24, 2013 1:44 pm
The Moriwaki points cover was easier to source than an original - Ebay
I'm pretty sure it came from the bloke who fronts Grumpysuzuki.com
Phil.
saxon46
#30 PostAuthor: saxon46 » Sun Mar 24, 2013 8:17 pm
cheers phil I'll have a look...........
THE BIKE LOOKS THE BOLLOCKS BY THE WAY :D :D :D
