Side stand
Side stand
I have upgraded the rear shocks on gpz 750 twin shock
But the side stand is too short and the bike leans too much
Any ideas of longer stands
Ta
Ta
Re: stand
ricky13 wrote:probably about 23cm
as for dropping the pressure in my tyres what the ....
thanks
If you dropped the pressure to the 5 psi that I suggested it would lower the ride height and then the stand would reach the ground sooner. Thus reducing the severe lean angle that you were initially concerened about.
If the height of your rear tyre was say 60mm, I reckon dropping it to 5 psi would reduce the "static load radius" to about 20mm.
If the height of your front tyre was say 55mm, I reckon the SLR would reduce to approx 17mm.
I hope this helps.
Jimmock.
I hate people I don't like !
jimmock wrote:Ricky,
I've just noticed you are "over the water" in Fife.
We'll have to meet up sometime.
Ricky - Not a good move, you will not get away in one piece. Folk have visited Jimmock and never been seen again. Some have been rumoured to end up in TESCO`s burgers.
