ST conversion parts
stevie g
ST conversion parts
#1 PostAuthor: stevie g » Sat Feb 09, 2013 4:37 pm
Hi Guys, I'm looking to convert my Z1000 ST engine to chain drive and as far as I know need the folling parts to do it, Output shafts or both gear clusters from Z900 Z1000 kickstart models, Gear selector drum and gear lever rod, Inner sprocket cover, outer sprocket cover with clutch worm drive. If any of you kind gentlemen have any of these parts and would like to sell them to me please get in touch, thanks $tevie.
stephen g mackay
london calling
#2 PostAuthor: london calling » Sat Feb 09, 2013 6:09 pm
Stevie,I'm pretty sure that if you take the shaft drive stuff of the engine it's just a normal Z1000 MK2 set up :??
You shouldn't need a different gearbox or anything.
If what I was told was correct the ST is the MK.2 motor with the bevel gear added.
Jack
stevie g
#3 PostAuthor: stevie g » Sat Feb 09, 2013 6:17 pm
london calling wrote:Stevie,I'm pretty sure that if you take the shaft drive stuff of the engine it's just a normal Z1000 MK2 set up :??
Ah OK. I do remember doing the same to a GT750 years ago and Don't remember having to do a great deal to convert it to chain. Certainly not gear selector drum anyway. What I'll do is wait for more info on here before I go any further, The less I have to buy and change the better, thanks man, $
stephen g mackay
london calling
#4 PostAuthor: london calling » Sat Feb 09, 2013 6:22 pm
Once you've got the shaft shite off the motor,you'll be able to see what you're dealing with.
Speak to Dave Marsden at Z-POWER for the kosher S.P. :wink:
Jack
Z1RII
#5 PostAuthor: Z1RII » Sat Feb 09, 2013 7:58 pm
you need the output shaft from any Z1-MKII engine, also gear selector drum and gear lever rod. inner sprocket curved cover from late MKII/LTD engine or J GPZ. Z1-early MKII does not fit without oil leckage.
at least if you want to use the better ST clutch you need the 8mm clutch push rod from GPZ ( Z1-MKII is 7mm) plus 8mm oil ring in inner sprocket cover .
stevie g
#6 PostAuthor: stevie g » Sat Feb 09, 2013 8:18 pm
Z1RII wrote:you need the output shaft from any Z1-MKII engine, also gear selector drum and gear lever rod. inner sprocket curved cover from late MKII/LTD engine or J GPZ. Z1-early MKII does not fit without oil leckage.
OK thanks, this is the kinda stuff I was waiting to hear so I can get it right first time.
stephen g mackay
stevie g
Re: ST conversion parts
#7 PostAuthor: stevie g » Sun Feb 10, 2013 12:39 pm
stevie g wrote:Hi Guys, I'm looking to convert my Z1000 ST engine to chain drive and as far as I know need the folling parts to do it, Output shafts or both gear clusters from Z900 Z1000 kickstart models, Gear selector drum and gear lever rod, Inner sprocket cover, outer sprocket cover with clutch worm drive. If any of you kind gentlemen have any of these parts and would like to sell them to me please get in touch, thanks $tevie.
Update: Just bought a NOS inner sprocket cover, so will not need that part.
stephen g mackay
dixiethedog
#8 PostAuthor: dixiethedog » Sun Feb 10, 2013 2:58 pm
Im interested to see how you go with this project,it sounds cool. Can I ask,why are you changing from shaft to chain??? I had an ST a while back,and the idea of never having to adjust a chain was right up my street. :D
One of my friends has 1 or 2 (not sure)GT750 engines he was going to convert to chain drive for a chopper project,which I can understand the need for a chain. Please tell me?? Ive seen a few shafties with modern wheels fitted,so It must'nt be that reason? I need to know!!?
Every silver lining has a cloud...
stevie g
#9 PostAuthor: stevie g » Sun Feb 10, 2013 4:12 pm
dixiethedog wrote:Im interested to see how you go with this project,it sounds cool. Can I ask,why are you changing from shaft to chain??? I had an ST a while back,and the idea of never having to adjust a chain was right up my street. :D
Hi, sorry I must have written it wrong. I own a KZ1000A1 without an engine and I've just acquired an ST1000 engine, not the whole bike. So I'm looking at changing just the engine from shaft to chain. If my memory serves me right changing a GT750 to chain is a pretty easy task, I done one years ago without any difficulty, and I'm no great mechanic. The reason I changed it was My Z750 chop blew up and I bought the GT engine, so I had a whole engine to take parts from. I think I used the bottom casing from the Z along with several internals obviously.
stephen g mackay
#10 PostAuthor: Rich » Sun Feb 10, 2013 6:52 pm
I Have all that stuff from a KZ1000 A3 you will have to buy the gear box as a whole as I won't split it. Let me know if you are interested and I will sort out some photos and prices.
oldzed
#11 PostAuthor: oldzed » Sun Feb 10, 2013 11:10 pm
Dixie.
I bought all the stuff to do this as well.
I decided it was worth doing for 2 reasons.
1 The ST has a massive swingarm pivot point so pretty much anything can be put in swingarm wise
2 The standard ST running gear weighs an absolute ton in comparison to even slightly more modern stuff.
And if you need any more reasons
The ST is the poor relation in the Zed line up so Its cheaper than selling it and getting a chain drive bike.
I can do it so i just want to
member number 0664
Who can catch a Kawasaki?
A police helicopter
#12 PostAuthor: paul doran » Mon Feb 11, 2013 10:31 am
I have all those parts from a MK 2 if You still need them
stevie g
#13 PostAuthor: stevie g » Mon Feb 11, 2013 11:17 am
Rich wrote:I Have all that stuff from a KZ1000 A3 you will have to buy the gear box as a whole as I won't split it. Let me know if you are interested and I will sort out some photos and prices.
PM Sent.
stephen g mackay
stevie g
ST conversion parts
#14 PostAuthor: stevie g » Mon Feb 11, 2013 11:18 am
paul doran wrote:I have all those parts from a MK 2 if You still need them
PM Sent
stephen g mackay
dixiethedog
#15 PostAuthor: dixiethedog » Mon Feb 11, 2013 5:24 pm
I like your outlook on the reasons for the chain drive conversion. :D
A friend of mine built a gt750 framed bike and used a hayabusa swingarm,that he had to add spacers too at the swingarm pivot! You could go for a 240 tyre in the back of your frame!
Do you want to buy a 240 tyre??? Ive a few. :lol:
Users browsing this forum: No registered users and 3 guests
