Engine paint
trekker-zed
Engine paint
#1 PostAuthor: trekker-zed » Wed Feb 06, 2013 12:12 pm
I'm in the process of checking valve shims on the Gpz in readiness for it's big comeback this summer :D
Needs the cam cover painting ( whole lot does really but it can wait till nxt winter )
The engine was painted years ago and i can't remember with what.
What good aerosol heat proof gloss black is being used these day's and where from.
Thanks.
Just noticed last tax disc sez 03 ! can't believe it's been that long. Oh dear !
big green bus
#2 PostAuthor: big green bus » Wed Feb 06, 2013 7:47 pm
B&Q plasticoat BBQ satin black does not burn off
saxon46
#3 PostAuthor: saxon46 » Thu Feb 07, 2013 5:00 am
b&q bar b cue paint..........painted a lot of my bike engines in this stuff,satin black so not too shiny and heat resistant..............cheap to :wink: :wink: :wink: :wink:
or if you wanna spend the money....pj1 engine paint is good also
mark ......english lad in wales....where men are men and sheep are scared !!!!!
Rhencullen
#4 PostAuthor: Rhencullen » Thu Feb 07, 2013 9:57 am
saxon46 wrote:pj1 engine paint is good also
PJ1 satin black was very good, and widely used on 900Rs, but it is now banned due to it containing something nasty apparently.
This Tech Cote product is a good alternative, that is more resistant to oil and petrol than BBQ paint.
1984 GPZ900R A1
2002 ZRX1200S
1981 Suzuki GS1000G + 1977 GT750B
KeithZ1R
#5 PostAuthor: KeithZ1R » Thu Feb 07, 2013 10:05 am
carefull with the BBQ paint its good stuff but it dont like petrol ! specially if it sits and catches in a well
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
#6 PostAuthor: zed1015 » Thu Feb 07, 2013 10:58 am
Simoniz/Sperex tough black.
This is the closest thing to PJ1 you can get.
The Techcote is shite, I bought 8 cans when PJ1 dissapeared and still have 7 and a half of them on the shelf.
Just whisper "petrol" near it and it falls off even after baking.
#7 PostAuthor: z1bman » Thu Feb 07, 2013 12:16 pm
wurth high temperature satin black
Big Fluff
#8 PostAuthor: Big Fluff » Thu Feb 07, 2013 9:19 pm
zed1015 wrote:Simoniz/Sperex tough black.
Agree with Rob ion all aspects here, the Techcote IMO is indeed shite.
The Siminoz 'Tough Black' is even better that PJ1 I reckon.
Rhencullen
#9 PostAuthor: Rhencullen » Thu Feb 07, 2013 9:42 pm
Big Fluff wrote:The Siminoz 'Tough Black' is even better that PJ1 I reckon.
Will have to give this Simoniz stuff a whirl guys, 'cos I'm sorely missing PJ1. Thanks for the heads up :)
1984 GPZ900R A1
2002 ZRX1200S
dixiethedog
#10 PostAuthor: dixiethedog » Thu Feb 07, 2013 10:29 pm
2pac automotive paint. Its available in any colour and works great on engines.If you look at the german streetfighter scene,they seem to have a thing for (f***ing horrible)orange and other horribly coloured engines.
One of my chops with a 2 pac painted engine.
[img][img]http://i596.photobucket.com/albums/tt50/lindarobjones/chopper%20stuff/102_3295.jpg[/img][/img]
The white parts on the frame were tape to stop any scratches when the engine went in.
Every silver lining has a cloud...
Keefleaf
#11 PostAuthor: Keefleaf » Thu Feb 07, 2013 10:40 pm
Etch prime 1st?
dixiethedog
#12 PostAuthor: dixiethedog » Thu Feb 07, 2013 11:26 pm
If the surface is bare metal,then yes,id etch prime. If your painting over a good (non lifting/flaking)surface,you can get away with just the 2K (2pac)paint. You could with enough time given,get the same shine on your engine as a set of nicely painted bodywork. :D
On a slighty off track subject,my good mate Robbie ( http://fumesngears.blogspot.co.uk/ ) preps his engines complete. He uses his mrs' rolling pin chopped up and inserted into the carb rubbers and exhaust ports before blasting the engine with a good power washer with a sand blasting attachment. The attachments are available for about £30-ish,and work a treat. He generally leaves engine in a bare silver,but the engines would paint up beautifully.
Just a thought. :D
malmojoe
#13 PostAuthor: malmojoe » Fri Feb 08, 2013 9:21 am
here are some options for VHT paints - all designed for use on engine so solvent and abrasive resistant, about £10 a pop, so £20-£30 for an engine:
Duplicolor does a great range in OEM colours with ceramic resins (so good technologies at low prices), think I'm going to try Ford semi-gloss black..
http://www.caswelleurope.co.uk/Duplicolor-High-Heat.htm
VHT Flame proof and engine enamels, again loads of OEM colours:
http://www.caswelleurope.co.uk/Paints_Coatings/high_temperature_coatings.htm
Krylon has a good rep amongst Mustang owners:
http://www.caswelleurope.co.uk/krylon-engine-paint.htm
Most paints made for BBQs and fires work at very high temps, but have no resistance to petrol. Also they are usually matt and go grey. Best use a paint developed for engines. Also it needs to conduct heat away and not insulate your cylinder and head. Not sure primer then 2k is a good idea.
dixiethedog
#14 PostAuthor: dixiethedog » Sun Feb 10, 2013 10:21 am
On the prep front I mentioned blasting the engine with a power washer with a sand blasting attachment,just wear your wellies. The carb inlets were blocked with a cut down rolling pin from the kitchen,the exhaust ports i think the same.
[img][img]http://i596.photobucket.com/albums/tt50/lindarobjones/project%20stuff/0005.jpg[/img]
It leaves a lovely surface finish for painting![/img]
trekker-zed
Sand blast pressure washer.
#15 PostAuthor: trekker-zed » Mon Feb 11, 2013 3:10 pm
Just a thought. :D
Any body else done this sounds like a very time saving way of stripping the old paint off me engine, but i'd be scared of getting sand in it even blocking off as above. Any feedback greatly appreciated.
Thanks for paint advice everyone.
