I need to investigate my Z1B starter clutch and therefor require a bolt to remove the rotor. I am aware the steering stem and rear spindle bolts fit but these are both chromed and so I don't want to damage them. I believe the bolt is m16 but I dont know the pitch can anyone give me the correct pitch and any tips for the removal of the rotor.
Alan
Starter clutch
Starter clutch
if you use the stem bolt put a suitably sized ball bearing against the shaft end first and forget about whacking it lock everything up and use a big lever on the socket
Keith
mistaken.
Phil Churchett winner 2013
mistaken.
zmaxmotorsports
- Regular Poster
KeithZ1R wrote:if you use the stem bolt put a suitably sized ball bearing against the shaft end first and forget about whacking it lock everything up and use a big lever on the socket
Exactly
10-72 (build date)z1/2-74 z1s/2-75 z1s/77 1428 turbo/77 1170/78 1170/74 z1 1385 turbo nitrous project/80 1000ltd 1327 z1 clone.........
That ol kaw was fast on the draw
Outgunned suzukis and outrunned the law
