Oil cooler size
harrythemagnum
Oil cooler size
#1 PostAuthor: harrythemagnum » Wed Jan 23, 2013 11:44 pm
Going to fit an oil cooler, what is the better size, 10 or 13 row?
What a wonderful philosophy you have,
#2 PostAuthor: Pigford » Thu Jan 24, 2013 8:54 am
Depends on engine spec - but a 10 row (how wide?) should be more than enuff :|
harrythemagnum
#3 PostAuthor: harrythemagnum » Thu Jan 24, 2013 9:30 am
Total stock motor.
I keep looking at the Jap bling bikes and most have thirteen row, but would I need an uprated pump with one?
#4 PostAuthor: Pigford » Thu Jan 24, 2013 10:23 am
harrythemagnum wrote:Total stock motor.
Oil pump will be OK - they chuck out big volumes, rather than pressure :wink:
The GPz11 only has a couple of rows... and that crates a fair bit more BHP (heat) :!:
Taffus
#5 PostAuthor: Taffus » Thu Jan 24, 2013 11:07 am
I think the GPz b1 has 3 row oil cooler, Z1100R 4 row
(\__/)
(")_(")Image
andy c
#6 PostAuthor: andy c » Thu Jan 24, 2013 2:06 pm
Ive fit a few coolers over the years, take into mind how much room you have including the mountings and what type and dimensions of fittings. Also check how much stearing lock you have, this may determine how wide the cooler can be
garyd
#7 PostAuthor: garyd » Thu Jan 24, 2013 4:29 pm
Used to ride my Z1 through London regularly and on really hot days and slow traffic it used to overheat enough to notice the loss of power even @ 30 mph.
andy c
oil cooler
#8 PostAuthor: andy c » Thu Jan 24, 2013 4:54 pm
If you are using the cable drive for the tacho this limits the room you have. If you are using electronic tacho and the head has had the cable drive blanked off more room. I used cable drive on mine ( see photo in last post) This limited me a lot on size of cooler. Hope this helps you.
Mr Puffin
#9 PostAuthor: Mr Puffin » Fri Jan 25, 2013 7:40 pm
Depends i have bought a ten row, which is 68mm high a 13 row would have been 90mm (not counting the input/output ports) you would need to measure up to see how much space you have available
harrythemagnum
#10 PostAuthor: harrythemagnum » Fri Jan 25, 2013 9:52 pm
All good stuff thanks guys, my first intention was a ten row, but I liked the look of the bigger cooler.
I am going to use the cable drive so ten row is the way to go I think.
