Harris Magnum 1
KWACKERZ1
#166 PostAuthor: KWACKERZ1 » Thu Dec 20, 2012 9:41 am
Rolling chassis is looking great those brakes should be fantaaaastic!
How much longer is the swinging arm than standard, as it looks very long.
I have one of those mk1 dual seat units and they are so 70's but just dont look right in todays world ?
The zed butt looks better but I think a 1000/900 would look better still as its that bit longer,
Other options
Harris F1 SEAT
h2r kr style seat.
GSXR Slabby seat from ragged edge
Personally I think the F1 seats suite them the best!
Crofty
#167 PostAuthor: Crofty » Thu Dec 20, 2012 10:04 am
looking good piglet, have to agree with others about the seat tho, too big. Is it possible to cut it down a bit?
Gus
#168 PostAuthor: Gus » Thu Dec 20, 2012 10:19 am
KWACKERZ1 wrote:GSXR Slabby seat from ragged edge
Ragged Edge went up in flames :shock:
"Set the GRINDER on it"
#169 PostAuthor: paul doran » Thu Dec 20, 2012 1:20 pm
Pigford wrote:
paul doran wrote:
Ginger Bear wrote:Looks fab Mark, wot with the modern brake & running gear. :up
BUT that seat unit.................................. :no :no :no
Steve I see You spotted the singular brake caliper too
nothing changes with Piglet then :lol: :lol:
Singular - your sights getting worse then Paully :roll:
too true Piglet
for a minute there I thought You were going to be consistent in the braking department
#170 PostAuthor: Pigford » Thu Dec 20, 2012 4:38 pm
Thanx for the input chaps - much appreciated :!:
Phil - I like the Harris F1 seat.......
Rob - Not overly keen on the KR1000 unit......
Got a few weeks to have a think about it, then hope to send stuff off to Simon :wink:
BRAKES: them things feel well VIOLENT just wheeling the bike about - should be able to perform stoppies at will (or by mistake more likely :shock: )
KWACKERZ1
#171 PostAuthor: KWACKERZ1 » Thu Dec 20, 2012 4:53 pm
#172 PostAuthor: Pigford » Thu Dec 20, 2012 6:28 pm
Cheers :wink:
#173 PostAuthor: Pigford » Thu Dec 20, 2012 7:39 pm
Think I'll probably stick with the Zed Butt as I better stop spending :??
Just need to sort out a decent method of fitting the seat unit - so it's easy to get on & off
Nothing stopping me sorting out the engine now :twisted:
#174 PostAuthor: ADRIAN H » Thu Dec 20, 2012 8:47 pm
Pigford wrote:Think I'll probably stick with the Zed Butt as I better stop spending
I like it . :lon :lon :lon
Crofty
#175 PostAuthor: Crofty » Thu Dec 20, 2012 11:10 pm
Piggy, it'll misfire as you have got plug leads on wrong :D
#176 PostAuthor: paul doran » Fri Dec 21, 2012 12:25 pm
Crofty wrote:Piggy, it'll misfire as you have got plug leads on wrong :D
:lol: :lol: :lol:
paulmceleney
Chunks
#177 PostAuthor: paulmceleney » Sat Dec 22, 2012 4:50 pm
The zed butt looks 100 times better
#178 PostAuthor: Pigford » Thu Jan 10, 2013 4:14 pm
Got the seat unit sorted - made a base with some alloy plate then stuck it together with a few 6mm bolts & some P38.
Made a real SIMPLE, LIGHT & EASY method of removing it..... I used a bucket handle :shock: as the wire is some sort of spring steel, and it passes thru' the seat-base alloy into some lugs on the seat rail.... and is a "spring-fit" !!!! The nose has a tang that fits under the frame, beneath the tank.
The wire is then clipped onto the seat nuts ...... :P
Next was the front muddy. It arrived today so I spent lunchtime (an extra long one) trimming it up and fitting it.....
Looking good now - ready to pack for painting .... but I'm still undecided what colours...... :??
The combo for TANK - SEAT - MUDDY will probably be BLACK & GREEN... but just not sure what to paint in what colour :?:
Mark Stratton
#179 PostAuthor: Mark Stratton » Fri Jan 11, 2013 1:40 pm
Thats looking bloody fantastic Mark.
Does the 657 refer to a certain group of gentlemen from Pompey? :twisted:
#180 PostAuthor: Pigford » Fri Jan 11, 2013 3:58 pm
Mark Stratton wrote:Thats looking bloody fantastic Mark.
Not that I was ever anything to do with it - but well spotted (Mr Docker) :wink:
