nipples
Best way is to use a small 'easy-out' stud extractor!
One of those things with a thread that goes the 'wrong way' so as you screw it in, it tightens up on the hollow nipple (snigger) and as its being turned anti-clockwise, the tighter it gets, the more UNSCREWING force it puts on the nipple
Not sure where to get such a small one from, but try a good tool or engineers shop (google)
right Paul, find the exact size of a good bleed nipple at the threads, then buy a drill 1.5 smaller and drill at slow speed down the centre of the broken nipple before using an easy out, then run a number three tap back down the threads before replacing with a stainless bleed nipple.
be sure to give the whole caliper a good clean to remove swarf before use, and if you dont feel comfortable doing the job, take it to a small engineering shop to have it done.
Good luck.
Good luck.
