Z1000 master cylinder reservoir removal......
gordon62
#1 PostAuthor: gordon62 » Mon Jan 07, 2013 12:22 pm
H i All,
I wish to remove the plastic reservoir part of both front and rear master cylinders, on my GS1000, they have 2 screws in bottom and then they come off, albeit bit of pressure, how do they come off on the Z1000, I dont see any screws,
cheers
#2 PostAuthor: z1bman » Mon Jan 07, 2013 12:34 pm
the round type are screwed in
gordon62
#3 PostAuthor: gordon62 » Mon Jan 07, 2013 12:58 pm
z1bman wrote:the round type are screwed in
Do you mean the plastic part screw"s in, or held in with metal screws...
scott
Junior Section leader
#4 PostAuthor: scott » Mon Jan 07, 2013 1:38 pm
There is normally a plastic insert that sits on top of those screws.....just use a bent piece of metal, kind of hook shaped will do and then just prise/pull up the plastic insert to reveal the screws.
gordon62
#5 PostAuthor: gordon62 » Mon Jan 07, 2013 2:18 pm
rear one done......
just gotta do the front one, the round insert seem not to wanna come out, but will try hooking it out....
cheers Guys.......
