Swingarm help
Fred the Zed
Swingarm help
#1 PostAuthor: Fred the Zed » Thu Jan 03, 2013 5:17 pm
Hi
Righto all of you recognition experts... Ive got hold of a alloy swingarm which is off a z900 or z1000 (I'm told).
It appears to be the right length, width and will fit my 78 Z1R but the shock mounts look different. The existing swingarm shock mounts are 'U' shaped with the shock lower mounts fitting between the arms of the 'U'.
On this swingarm it appears that the shock bolts either against or around the mounting.
Questions...
1. Any idea of the make... I was told Metmachex and have no reason to doubt the seller
2. Will my current Z1R shocks fit this swingarm or do I need shocks with an inverted 'U' lower mounting?
Any answer if you are sure you are right please.
BTW... Maxton will custom build a pair of shocks to fit your bike and to suit you as an individual for £440+VAT. Not bad, I thought.
Cheers!
Fred
steve.w
#2 PostAuthor: steve.w » Thu Jan 03, 2013 5:34 pm
defo metmachex and i believe u just fasten shocks on outside .. same set up as one i had on my mk11 years back :wink:
dixiethedog
#3 PostAuthor: dixiethedog » Thu Jan 03, 2013 5:40 pm
Id agree with the Metmachex brand thing. Ive a couple of JMC swingarms,and they are different to that one. Why not check out quad bike shockers,as you can get new remote (ohlin style)ones for not a massive amount of money?? Or monoshock it! :D Go for a Yam thunderace arm,which if you squint looks like an expensive overpriced but lovely Santuary one......Just a thought.
I figure you know the style you want? :D
Every silver lining has a cloud...
Fred the Zed
#4 PostAuthor: Fred the Zed » Thu Jan 03, 2013 5:43 pm
Cheers Steve and Brett!
I'll put the Z1R apart soon and fit it to see what it looks like. I'll do a 530 chain conversion at the same time to lose some more weight off the rear. Is it just Debbens that do the conversion kits?
#5 PostAuthor: chrisNI » Thu Jan 03, 2013 6:02 pm
Debben do kits but you can just buy sprockets and a chain. Talon or B+C for sprockets anyone for chain. Just whatever you find easiest and cheapest.
Those forked bottom shock mounts tended to be on Suzuki shocks. It may have been an arm originally ntended for a GS1000 or something later used in a Zed. The mounts could be replaced with the U type if you wanted to.
steve.w
#6 PostAuthor: steve.w » Thu Jan 03, 2013 6:07 pm
chrisNI wrote:Debben do kits but you can just buy sprockets and a chain. Talon or B+C for sprockets anyone for chain. Just whatever you find easiest and cheapest.
i bought a brand new one for my mk11 (only because me mate has a bike shop next door got mega discount) it came with same type mounts ... dont think ive seen metmachecs with u type ,, but im sure somebody will correct me if im wrong :wink:
dixiethedog
#7 PostAuthor: dixiethedog » Thu Jan 03, 2013 6:44 pm
When I said monoshock i wasnt thinking of xjr13 swingarms which also look like the expensive Sanctuary ones.
Dont take any notice of me though. :D
#8 PostAuthor: Al » Thu Jan 03, 2013 7:49 pm
This used to be the same swingarm as the one in youre picture. Now drastically altered as you see it and little of the original remains, but has the threaded shock mounts on the inside of the lower shock bushes as yours does.
I put nuts on the inside of the mounting ears as well for a bit of peace of mind.
http://www.z1ownersclub.co.uk/forum/vie ... 44&start=0
z1000puddin
#9 PostAuthor: z1000puddin » Thu Jan 03, 2013 7:54 pm
Yeah.
Shocks fit to the out side
Zed til Dead
Fred the Zed
#10 PostAuthor: Fred the Zed » Thu Jan 03, 2013 8:21 pm
Cheers guys, thats all really useful info.
I'm loving that drag racing Z1R.... best buy some more lottery tickets if I want to go that way.
All the best
Fred the Zed
mikeyoz1
#11 PostAuthor: mikeyoz1 » Fri Jan 04, 2013 4:54 am
Nice ride !!
