What fork tops are these please??????
Gus
#1 PostAuthor: Gus » Thu Jan 03, 2013 1:24 pm
Hi Guys.
Picked up some forks and I haven't seen these balance valves before.
Are they standard or not?
Any help would be much appreciated.
The casting numbers on the fork legs are K207L and K207R and I don't know what that means either :roll:
Ta muchly in advance.
Gus
"Set the GRINDER on it"
steve.w
#2 PostAuthor: steve.w » Thu Jan 03, 2013 2:47 pm
they look like gpz1100 b1/b2 forks ..with a homemade balancer grafted on :idea:
Gus
#3 PostAuthor: Gus » Thu Jan 03, 2013 3:08 pm
36mm tops and Z650/1000 bottoms by the look of them.
I was hoping someone could tell me if the K207 number relates to 650 or 1000 fork bottoms.
Gus
#4 PostAuthor: zed1015 » Thu Jan 03, 2013 3:37 pm
Both z650 and z1r disc brake fork lowers have K207 cast on them.
Don't know about other models.
650 legs have circlip above fork bush, Z1R doesn't.
Your lowers have a slightly different shaped mudguard lug on them though.
Gus
#5 PostAuthor: Gus » Thu Jan 03, 2013 4:09 pm
zed1015 wrote:Your lowers have a slightly different shaped mudguard lug on them though.
Thanks for the reply.
I've seen that shape mudguard mount on MKII forks.
Also they bear a very uncanny resemblance to these!!!!!
Gus
#6 PostAuthor: zed1015 » Thu Jan 03, 2013 5:57 pm
Yep! those are the same.
Probably a sign you need to build moriwaki rep ? :lol:
Gus
#7 PostAuthor: Gus » Thu Jan 03, 2013 6:23 pm
zed1015 wrote:Probably a sign you need to build moriwaki rep ? :lol:
I knew there was a reason I bought them :lol:
KeithZ1R
#8 PostAuthor: KeithZ1R » Thu Jan 03, 2013 8:43 pm
Two sets Z1R fork legs both off 78 bikes one UK one American identical and all have 207 stamped on em along with with L and R
sorry about the pic not much light in the loft :oops:
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
Gus
#9 PostAuthor: Gus » Thu Jan 03, 2013 8:46 pm
Thanks Keith.
I'm erring more towards the thought that they are MKII
Gus
Z1parR
#10 PostAuthor: Z1parR » Thu Jan 03, 2013 9:18 pm
These are my two ? sets of Z1R forks so i thought :??
0172 . Geoff Parr
