Any one out there with a parts diagram that can let me have the part number for the rear reflector that bolts on to the bottom of the UK Z1100A shaft.
The parts diagram I have access to is for the american short "fender" model with no reflector.
Part number for the rear reflector on a Z1100 shaft
Hi Padders, is it the same one as on the Z1R? if it is which it might be its 28012-1002, which is no longer available, however if it is the right part then the reflector off the H***a cx500 is the same part, part number 33741-415-602 can get it from David Silver spares, unless a Z1R owner has a spare
Padders, høw about csml.com they list a few 1100`s but all under the kz logo
http://www.cmsnl.com/search/index.php?s ... 0&spbmvin=
