Z1r l/h switchgear usa one same as uk one ?
ross
#1 PostAuthor: ross » Tue Dec 18, 2012 9:16 am
Hi, is the american l/h switchgear the same as a uk one, for a 78 z1r. think a usa one has some wires in a block connector. Regards ross
# 364
78 z1r
78 z1r monoshocked
78 z1000 a2
83 z1000r elr
83 z1000r elr monoshocked
#2 PostAuthor: z1bman » Tue Dec 18, 2012 9:35 am
pretty sure this could do the same job
http://www.ebay.co.uk/itm/Kawasaki-Left ... 4d016f2b82
Zed man
#3 PostAuthor: Zed man » Tue Dec 18, 2012 11:13 am
I have restored a set of Switchgear for a zed A4, and in the link for eBay, why is that big lump underneath for/do? :(. And why so much?
ross
#4 PostAuthor: ross » Tue Dec 18, 2012 11:48 am
The big lump underneath is for the self cancelling indicators/ hazards. Not the prettiest of switches....but want switchgear original
# 364
78 z1r
78 z1r monoshocked
78 z1000 a2
83 z1000r elr
KeithZ1R
#5 PostAuthor: KeithZ1R » Tue Dec 18, 2012 12:49 pm
The switch is basically the same however you need to realise that the wires exit from the front of the switch in the majority of cases not down the bars and it also may be missing the headlamp flasher element as that was not always fitted , the lump is a solonoid for the self cancelling indicators I can post pics if necessary of the difference........... The beltdrive 440 is a good idea but you WILL have to either hard wire it or change the connectors and the colours are different but again the wires exit from the front of the switch (it never rains in the States :roll: ) hope this waffle makes sense
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
#6 PostAuthor: z1bman » Tue Dec 18, 2012 7:21 pm
the z440 switch is probably identical apart from the wiring might be a different length easily sorted. as for the wiring colours kawasaki wiring is pretty much unchanged to this day regarding which colour wire goes to what electrical item on the bike
