Z1r l/h switchgear usa one same as uk one ?
Hi, is the american l/h switchgear the same as a uk one, for a 78 z1r. think a usa one has some wires in a block connector. Regards ross
# 364
78 z1r
78 z1r monoshocked
78 z1000 a2
83 z1000r elr
83 z1000r elr monoshocked
78 z1r
78 z1r monoshocked
78 z1000 a2
83 z1000r elr
The switch is basically the same however you need to realise that the wires exit from the front of the switch in the majority of cases not down the bars and it also may be missing the headlamp flasher element as that was not always fitted , the lump is a solonoid for the self cancelling indicators I can post pics if necessary of the difference........... The beltdrive 440 is a good idea but you WILL have to either hard wire it or change the connectors and the colours are different but again the wires exit from the front of the switch (it never rains in the States
) hope this waffle makes sense
Keith
mistaken.
Phil Churchett winner 2013
mistaken.
