Originally built by Jack o'malley (founder of Orient express performance) this bike was imported from the states by the late Steve Tong and is thought to possibly be the first of its type to be brought over.
Here's a pic of the machine as it should be.
And here as it has been for nigh on 30 years since it blew over the line at long marsden
I have now got the engine and spares on the bench for inspection
Pulling the barrels reveals the the cause of the engine failure .
Both center pistons suffering from detonation and the excesssive heat that running 30psi of boost will create.
A little mystery for now is how this lump of sump got ejected from its moorings ?
Initially i thought the the camchain had snapped,wrapped around the crank and had destroyed the main bearing cap with shrapnel exiting through the sump, but a quick inspection revealed the chain is untouched and peering through the hole shows the cap intact and everything turns freely
It should all become clearer once i get the sump off
A couple of gems were revealed whilst sorting the good spares from the bad
"New" welded crank from Chris Applebee still in the kawasaki box soon to be woken from it's slumber.
And belt and braces approach to clutch slip .
Who need steroids
