LATEST PROJECT
#16 PostAuthor: ADRIAN H » Wed Nov 28, 2012 8:22 pm
brian 450 wrote:Image
good start, love the alloy tank. :D
brian 450
#17 PostAuthor: brian 450 » Wed Nov 28, 2012 8:36 pm
The tank isn't alloy it's steel I have stripped the paint off. I got it from the states it's off a 1967 benelli mojav same age as me. The plan is to let it go rusty and then mat laquer it or paint it mat black or mat silver
Is Vic There
#18 PostAuthor: Is Vic There » Wed Nov 28, 2012 11:52 pm
I've been looking at the front end for the last 10 minutes, just trying to see what wheel you were using, glasses on, looked again! There's not one there! :D
brian 450
#19 PostAuthor: brian 450 » Thu Nov 29, 2012 6:48 am
:lol: that's a new design
brian 450
#20 PostAuthor: brian 450 » Sat Dec 01, 2012 6:36 pm
Bought two exhaust systems, played about with one cutting it up. I now have 2 into2 headers, I am going to get a pair off megaphones. I decided to make something up as there is nothing available that looks ok, they are all like a pair off scaffold tubes down one side not really any good for a cafe racer look
Royalratch
#21 PostAuthor: Royalratch » Tue Dec 04, 2012 6:20 pm
Love this.
brian 450
#22 PostAuthor: brian 450 » Wed Dec 05, 2012 11:35 am
Seat should be here soon just tracked it and bloody customs have got it!!!!!! Just got to wait for them to work out how much they are going to sting me bastards :evil: front wheel is made now so should have it fitted next week.
brian 450
#23 PostAuthor: brian 450 » Mon Dec 10, 2012 9:59 pm
Spent sat cutting and shutting header pipes to shape. Tempory bolted it on ready to weld it all together and make the hangers. Also bent some tube for subframe, so when mounts are made i will crack on with subframe over xmas. Tank has has had the neck cut off and a brass neck has been silver soldered to the tank for the monza cap. Hopefully the front wheel should be here tomorrow from the wheel builders so once i have painted one more disc and fitted tyre it will be in. Also swingarm is coming out to have the braces cut off and some tubular ones fitted spaced out even both sides as i don't like the way they are at the moment uneven.
brian 450
#24 PostAuthor: brian 450 » Mon Dec 10, 2012 10:03 pm
brian 450
#25 PostAuthor: brian 450 » Mon Dec 10, 2012 10:04 pm
brian 450
#26 PostAuthor: brian 450 » Mon Dec 10, 2012 10:05 pm
brian 450
#27 PostAuthor: brian 450 » Mon Dec 10, 2012 10:08 pm
brian 450
#28 PostAuthor: brian 450 » Mon Dec 10, 2012 10:08 pm
brian 450
#29 PostAuthor: brian 450 » Mon Dec 10, 2012 10:10 pm
Also made speedo bracket and removed handle bar clamps.
brian 450
#30 PostAuthor: brian 450 » Mon Dec 10, 2012 10:10 pm
Return to “The Bottom Shed”
Users browsing this forum: No registered users and 0 guests
