z1000j2 ...keys lost...
timyoungman
#1 PostAuthor: timyoungman » Tue Nov 27, 2012 2:31 pm
I am looking for a key for a z1000 j2. The seat lock is stamped 024-0T17.
I can't find a number on the ignition barrel but I might not be looking in the right place.
Can anyone tell me if the code above is a key code and where to get a key please. Or, where to look to get the correct key code ??
Thanks :??
#2 PostAuthor: z1bman » Tue Nov 27, 2012 4:12 pm
no the number you have is not the key number it should begin with Z5 **** it is stamped on the ignition switch + on the metal plate on the back of the r/h helmet lock you might need a magnifying glass to see it as it is very small. if you know the key number this company is excellent + a few members have used this company
http://www.ashfieldsecurity.co.uk/
timyoungman
thanks
#3 PostAuthor: timyoungman » Tue Nov 27, 2012 5:48 pm
Thanks.
I can't read the number on the helmet hook and will need to re-examine the ignition switch...
If not it's a new lock set I need. :|
#4 PostAuthor: z1bman » Tue Nov 27, 2012 6:29 pm
you will have to remove the ignition lock to see the number it is normally stamped below the main shaft of the switch either on the aluminium casing or on a steel plate around the steering lock
timyoungman
Found it !
#5 PostAuthor: timyoungman » Tue Nov 27, 2012 9:34 pm
Thanks again.
I found matching numbers on all 3 locks....and have asked the locksmith you recommended...
Easy when you know how !
Cheers.
#6 PostAuthor: z1bman » Tue Nov 27, 2012 10:21 pm
that's good news you should get the key next day
timyoungman
Additional info.
#7 PostAuthor: timyoungman » Wed Nov 28, 2012 1:46 pm
Just to let you know I located another key cutter in New York who does great deals.
A key for my bike, cut to code and posted 1st class USPS cost only £12.50 at todays rate !
Here's the link for z1000j .. ..( and other Z models..)
Just type in your code and away you go.....
http://www.key-men.com/shopping/show_ke ... atnum=KA14
#8 PostAuthor: z1bman » Wed Nov 28, 2012 5:53 pm
were are you from timyoungman?
timyoungman
#9 PostAuthor: timyoungman » Wed Nov 28, 2012 6:40 pm
Perthshire,Scotland..
timyoungman
#10 PostAuthor: timyoungman » Wed Nov 28, 2012 6:47 pm
Ashfield security came back to me with this message so I went for the American supplier who seems to only have 1 option for roughly the same cost..
-----Original Message-----
Sent: 28 November 2012 12:59
Subject: RE: Contact from ashfieldsecurity.co.uk
This code gives me two different cutting patterns. These keys would cost £7.25 each including VAT plus and extra charge of £6.00 for delivery including VAT if required.
Please e-mail back.
Regards,
James
