I am looking for a gearbox output shaft to put in some surplus cases to use as a jig for frame mods. I just need it to get the chain alignment right so the gears can be broken/missing as long as the gearbox sprocket sits in the right place. Ideally would come with the larger bearing and the set ring.
thanks
Z1/Z900 gearbox output shaft, condition not important
neilbarrett
