Frame and engine numbers
Heres one for you guyz, a mate of mine has just bought a very modified Z which is a none runner and is trying to id the engine and frame models so he can try and get an accurate wiring diagram.
Frame number is KZT00J-000715
Engine number is KHI 35468600
I havent seen the bike but the engine as described sounds like a Z1000J
Any ideas what year and model they were originally?
KHI is an abbreviation of Kawasaki heavy industries + i have never seen this prefix on any Kawasaki engine number. in reply to pigfords suggestion that the engine might be a factory replacement i would say it is highly unlikely + would either come ready stamped with the identical number or would have come through blank for the dealer to duplicate the old number on to the new engine. i remember when the z1300a1 came out with the small sump I replaced 3 motors supplied from the factory with the original numbers stamped on from the factory. i also replaced 2 2004 zx10r motors from the factory but these came through with no numbers on so it was up to the dealer to transfer / stamp the old engine number onto the new engine. it looks to me like you have a dodgy engine in your mates bike ???
OK guys, just got some pics to post and on first look it is a J motor aswell as the frame but looks like a decidedly dodgy engine number unless it is a dealers half arsed attempt at stamping the number on a blank replacement unit.
Your thoughts Gents.......
Looks like the original number has been ground off and another number stamped on ...very badly!
Could it not be a re-stamped eng # from a stolen / recovered engine ???
As long as it corresponds with the V5 it should be ok..?
This is more of a question than a statement by the way, as my 79 A2 has the correct frame #... but a eng # Z1R******
same as V5. 1015cc barrell stamp, round-ended rocker cover etc. Previous owner wasnt sure of history either.
- coldsummer
