z1000j fuel tank
lombardrac
z1000j fuel tank
#1 PostAuthor: lombardrac » Fri Nov 16, 2012 3:34 pm
hi has anyone a tank and tail piece for sale
thanks lee
better to Burn Out than to fade away
#2 PostAuthor: Ginger Bear » Fri Nov 16, 2012 4:12 pm
Lee I have a tailpiece with all mounts intact, only downside is that it has a 20mm hole cut in one side, presumably for an alarm key or something similar. Should be easy to repair.
Yours for £20 (I paid more :oops: ) + postage or you can collect from Bristol. I'll post a couple of pics if you're interested.
# 104
lombardrac
pm
#3 PostAuthor: lombardrac » Fri Nov 16, 2012 7:39 pm
ginger bear you have PM :D
#4 PostAuthor: Ginger Bear » Fri Nov 16, 2012 7:47 pm
You have a reply!
# 104
lombardrac
#5 PostAuthor: lombardrac » Sat Nov 17, 2012 10:34 am
tail piece sorted, excellent
many thanks, ginger bear....
lombardrac
#6 PostAuthor: lombardrac » Tue Nov 20, 2012 7:11 pm
still looking for a tank
z1000j
z1100r
gpz1100 b1,b2.
can anyone help, need to change the look of the mad cow...
fan koo
lee
#7 PostAuthor: Al » Tue Nov 20, 2012 7:36 pm
Looks like an early frame so fitting a J tank may be a faff.
The J tank is also pretty fat 'up front'.
Wondering if you might run into problems with steering lock!
lombardrac
#8 PostAuthor: lombardrac » Tue Nov 20, 2012 7:48 pm
bollo$ you are right, just looked at the original write up in streetfighters.. its a z1000 mk2. well spotted shame i love the look of the bigger tank
lee
