Is there anything special about the o-rings that seal it to the case ?
I couldn't work out if they had a flat profile because they've been compressed for 30 years, or if they're meant to look like that.
Will any new o-ring of the right size do ?
I was going to buy a 440 piece o-ring kit so I'd always have a stock in the workshop, but I see I can pay from £6 on eBay to £50 for o-rings made from 'viton' .
As far as I can make out cheap = made from 'nitrile' and good to 120c.
Expensive = made from 'viton' and good to 200c.
What are you supposed to use in bike engines ? Can't seem to find the answer anywhere else.
Thanks for reading.
