z1100r hydraulic clutch conversion
rc30rob
#1 PostAuthor: rc30rob » Sun Jul 22, 2007 9:56 pm
Hi all has anyone done this conversion on an ELR or know anything about it ,ie slave cylinder to use etc,thanks rob
Nolite id ,cogere ,cape malleum majorem
#2 PostAuthor: Rich » Mon Jul 23, 2007 5:11 pm
If you use a 33mm dia slave (zxr etc) use a 5/8 bore m/c it will give you more movement. Ducati slaves are 25mm bore and will fit your clutch rod nicely use a 14mm m/c with these. Slaves are available from Germany to fit inside std covers ( probably from USA as well) ask Padders - he's bought one.
If you want strong springs and light clutch try and find a P&M clutch actuator.
Iain marshall
#3 PostAuthor: Iain marshall » Mon Jul 23, 2007 5:42 pm
P&M type clutch lifter
and a Millington special
Padders
#4 PostAuthor: Padders » Fri Jul 27, 2007 4:57 pm
This is the guy I bought the hydraulic clutch from that Rich mentioned. Top guy delivered within 4 days fitted perfect.
padders
250146598146 e bay ref
#5 PostAuthor: Rich » Fri Jul 27, 2007 6:36 pm
Got a nice gold chain to match it now Iain :wink:
