1100 Septic StreetRod/Cafe Racer
Mr Puffin
Re: Tim's Septic!
#31 PostAuthor: Mr Puffin » Mon Nov 05, 2012 8:00 pm
Timothy Comerford wrote:Hi Mr Puffin. I knew it was only a matter fo time till the Septic became a topic for discussion. You can't keep a good thing down! I have only done a couple of hundred miles on my one.. It goes well but the orignal shocks were knackeres. I now have a set of Hagons thanks to Paul,
Good luck with the re-build ..........and enjoy the begrugers!!
Tim.
:D
Yes i suppose it was bound to happen Tim, it does not seem to long ago that the J`s and twin shock GPZ`s were viewed as the devils own offspring and would they ever be classics or allowed in the club. best not mention the unitracs :lol: Time marches on. Another few years and Paul with have several septics.........
Are you pleased with the Hagons performance, im looking for a Budget shock to replace the original Air ones, just to make the bike look lighter and not so lumpy :mrgreen:
Mr Puffin
#32 PostAuthor: Mr Puffin » Tue Nov 13, 2012 12:09 pm
With the electrics now more or less sorted or at least working i have moved up front removing the stock headlamp brackets
Revealing perfect tubes :) As part of the(more) streamlined look, simple headlamp brackets will be fitted. The air balance tube will be removed and the holes in the legs plugged. The other fork leg will require drilling tap and an air valve. Lock stop looks to have taken a hit so will have to have a close look at that lower clamp when it comes apart. New seals are on the way, i will need dust covers
The first of the ordered in parts has arrived with a bargain manual camchain adjuster from MPL :bla
Mr Puffin
#33 PostAuthor: Mr Puffin » Tue Nov 13, 2012 4:13 pm
Some messing around with various rearsets i found these water boiler GSXR ones matched the angle of the frame. Unfortunatly i feel they move the pegs too far back in fact 26cm further back than the lazy stock pegs
Some more digging and a found the 916 brake mastercylinder which looks pretty cool. I hope its up to pumping the Zeds caliper :?:
and some wood to make templates for the hangers cheaper and more forgiving than wasting alloy plate :) im aiming for 16-17cm further back than stock. i think i really need a 4-1 in place before finalizing the peg placement. Anyone got one for sale :wink:
Image :wink:
Mr Puffin
#34 PostAuthor: Mr Puffin » Sat Nov 24, 2012 6:51 pm
Moving on With a couple of spare hours this afternoon i got the hacksaw out and removed some of the original seat mount brackets. To clear the way to fabricate the seat/tailunit.
The seat rails are probably going to need tweeking upwards as they sit very low compared with a J or GPZ
Parts :| as usual slow things down while you have to wait, but its all part of the process :cry: Good to know things are in transit......
UT clocks
and the Kerker i won on ebay last night :D $125 + shipping :wink: Instant street cred even for a Septic
#35 PostAuthor: Rich » Sun Nov 25, 2012 8:22 am
rear M/c is upside down in your pics,
Mr Puffin
#36 PostAuthor: Mr Puffin » Sat Dec 01, 2012 8:56 pm
Rich wrote:rear M/c is upside down in your pics,
makes absolutely no differance Rich, the m/c will function no matter how it is placed as long as the resevoir is placed higher and the system is bled :wink: The main point here being keeping it clean.
I\m looking at Christmas before the kerker arrives from the US :| So i have robbed the one off my J just to help get the footrests placed. One thing that is very obvious :?? The swingarm pivot is further back on the septic (compared with a j ) so the link pipe is going to need a little work, so im stuck anyway as i dont want to chop this one :twisted:
The Kerker does look cool though :twisted:
Mr Puffin
#37 PostAuthor: Mr Puffin » Thu Dec 06, 2012 7:31 pm
The pipe is here :shock: Super Fast shipping, a new record perhaps and straight through customs without any value tax :D
Mr Puffin
#38 PostAuthor: Mr Puffin » Thu Dec 06, 2012 7:48 pm
The Headers are in real good shape with only some light rust + 1 small dent. The can is split at the end cap bolt hole and has obviously had a hard knock at some point
This dent is hopefully out of sight
The Baffle is missing too so im thinking cut the can down open up the outlet and make/fit a larger baffle like GB did in one of his builds.
Fingers crossed Hansen will round with the Boses for the frame/footrest mounts + tube for the seat rails at the weekend so i can get moving. Would be nice to have the frame back from paint before Christmas :wink:
#39 PostAuthor: Ginger Bear » Thu Dec 06, 2012 7:56 pm
There ya go Mr Puffin.......
..... A bit of inspiration for you!
# 104
Mr Puffin
#40 PostAuthor: Mr Puffin » Thu Dec 06, 2012 8:37 pm
Ginger Bear wrote:There ya go Mr Puffin.......
Thanks GB i was just about to PM you :D found your thread but the can surgery was missing... :| Ihad forgot you had gone Black with the can :fro The larger outlet certainly looks Good, do you remember the perforated tube size :?:
Users browsing this forum: Bing [Bot] and 11 guests
