33 smoothbore carbs
paulmceleney
- Chunks
33 smoothbore carbs
These carbs keep flooding i think found the problem ,the float is sticking but i can not see why, when you turn the carbs upside down one is not droping in to the closed position like the over three i have clean the pin it will drop sometimes then it will stick open
needaz1100r
paulmceleney
- Chunks
check the float bowl breathers
Hi,Just was wondering if it's a similar problem that i had on my 33mm smoothbores,flooding out of the air jets at the rear of the carb's,tried everything until i noticed the float bowl breather tubes had been blanked off!
there are 2 breathers which i left open and one fuel tap vacumn which needs to be left plugged up if not running a vacumn fuel tap,hope this will solve your problem,mines running fine now.
cheers,Stan
cheers,Stan
"We're in a sticky situation all right. This is the stickiest situation since Sticky the Stick insect got caught on a sticky bun."Blackadder series 4
Kawasaki Z900
Ducati 900 monster
H**** RS250 gp bike
Kawasaki Z900
Ducati 900 monster
H**** RS250 gp bike
paulmceleney
- Chunks
no out of the float bowl, i have fix it now. Its running on all four cylinders and the plugs are nice colour, but number 3 cylinder header is not as hot as the other 3, when putting the carbs back on ,i notice that on number3 looking into the carbs from the back the slider is a different height to the others i have been told this will make it run lean on that cylinder i am not sure how to adjust this so, i plan to take the tops of the carbs of and see if it will adjust there so they are the same
