21066-026 REGULATOR ?
I'm slowly bringing an Ozzy Z900A4 (same spec as your UK ones) back from the dead, in Marsdens Zed parts book is listed this regulator on page 59 for the A4, my wirings a mess but can't find it also can't find in a couple work shop manuals I have, any ideas what's it for? is it needed? where can I buy one?. Appears to be a push inline jobby, maybe for head light when switching from low to hi?
many thanks.
many thanks.
- DogsbolloxofZ1B
I've seen these often...
These items have nothing to do with the ignition coils and, I believe, they were a resistor in the headlight circuit to avert that "moment of darkness" when going from high-beam to low-beam and vice-versa.
They are positioned under the tank and are connected to the blue connectors from left & right-hand h'bar controls. I have never bothered with them and never had any adverse electrical problems.
The ignition "ballast" resistor is coil related and is a much larger resistor mounted on a special mount under the tank, near the headstoc, present on Z1R, Shaftes and others.
DogsbolloxofZ1B wrote:Fits onto to hazard relay Z900-A4 and Z1000-A1, without it they don't flash proper.![]()
Mike
Bingo, found it, actually never lost it, was there all the time, couldn't see for looking, small bugger ain't it.
I was lookin for somethink more substantual, bout the size a spark plug cap.
Strange my Ozzy Z1000A1 doesn't have one, but thats being butchered.
Thankz Dogs and all.
