A Little more progress to post, but it seems like slow going... Got the frame and swinger back from Northumbria Coatings
and I am very impressed at the job they have done. Sandblasted back to bare metal and they even masked off the threads
and headstock etc. and finished in gloss black. I went for the (more authentic ?) paint rather than powder coating.
I've been trying to get all the bits prepped that are to get re-zincplated and there was quite a bit of the original nuts and bolts
missing or changed to accomodate the US style mods so there is a lot to replace and its easy to overlook something that you
remember during the rebuild.
I must get the crancase bolts sent off so I can start the engine rebuild. Only the rocker cover left to paint but I need to polish the end caps
before I paint it.
Masking off and blanking threaded holes takes most of the time for this job.
Removed the old tyres and stripped down the wheels so the hubs can be painted and polished and the rims sent off for re-chroming . Been thinking about replating
the original spokes and nipples seeing as they're in pretty good shape, has anyone had this done?
There's plenty thickness on the brake disc so a tickle on the ring grinder will only take a few thou off to leave a nice new look finish.
A good look at the wiring harness showed lots of botched scotchlock wiring mods and bad connections causing plugs
and sockets to overheat and burn. Too bad to just repair so a whole new wiring harness from Z-power will be going in this one.
More progress reports coming soon
