The green will be similar and there may be some stripes
with the torquearm mounted on the frame will this effect the suspension under brakingPigford wrote:Crofty - why not change the torque arm to summink a bit more refined
I got a length of M10 s/s studding, a bit of 10mm alloy tube and a couple of M10 ball joint thingies - and voila
Cheap & effective - and a bit lighter tooKeep at it - great stuff
