the bike has been burning and or losing oil.
There is a little bit of smoke out the exhaust so its burning some.Also a bit of a weep around the head gasket.Not sure why as was a new gasket fitted when i put new valves in last winter.
would a compression check tell me if the oil is also leaking into the cylinders.
Is there a way to check if its a valve seal.
lve left it till now as the bike still runs great.
Losing oil
Losing oil
keep thoses wheels turning
wilsonsjw11
Yep sounds like stem seals were they genuine ones fitted?Ditto was the head gasket and head to barrels o ring gen? all classic cases of oil leaks if reporos used!!!!!!
- toycollector10
