too much compression ??
Hi All
just a question that might prevent me breaking my ankle....My Z1B is bored out to 1015 and apparently the head has been skimmed for greater compression, I was informed about this by the guy who did an engine rebuild for me about 14 years ago.....anyway I have always had to start it from cold with the kick start as the electric although ok when the engine is hot does not seem to have the oomph to fire it up from cold, do I need to upgrade anything i.e. higher voltage starter motor or battery?
I find as time marches on its a pain to put it on the centre stand get the kick start to it`s topest position and do gymnastics to get my full body weight crashing down on it several times (you would not believe the bruises from wearing unsuitable boots and kick backs)
any top tips ?
Bob
any top tips ?
Bob
Providing the battery is good:
Replace both starter feed and the main earth cable, 16mm2 welding cable is good.
If that doesn't work check starter brushes and commutator, get it skimmed and clean out the mica slots.
A CB900 starter motor will give more power than Z900/1000 units. You will have to alter the sprocket cover casing or it is possible to skim out the starter and relocate the brush holding plate if you have access to a lathe.
1400cc with high compression motors start with no problem on the button so if 1015 wont then its probably poor battery, Yuasa batteries are good, poor wiring, or often its the starter motor now, many starter motors have had no attention whatsoever in 30 years, it could also be ignition timing issue down to weak spark, so check ignition, coils and leads, Dyna ignitions are good. Hope you nd you can sort it
						- big green bus
				neilbarrett
