Left side handle bar switches
DaveZ1
#1 PostAuthor: DaveZ1 » Thu Oct 18, 2012 1:21 pm
I have got a damaged left hand side bar switch with the Hi Lo switch knob missing and the actuator broken. Looking for another one that I can use the bits to restore/fix mine Its off a 73 US spec Z1,
Cheers, Dave
#2 PostAuthor: chrisu » Thu Oct 18, 2012 4:35 pm
you could always get a new switch and gut that for the internals/wires etc
DaveZ1
#3 PostAuthor: DaveZ1 » Thu Oct 18, 2012 5:32 pm
Have thought about that Chris but not sure if the guts of a new one would fit the original shells. Are they the same internally, anyone know?
kawamick
#4 PostAuthor: kawamick » Thu Oct 18, 2012 5:33 pm
Have a correct left and right hand switch stamped 3.11 for sale.
Mick
'78 Z1R, '80 Z1RII, '76 Z2 Z750 A4, '75 Z1 AME chopper, '80 Rickman CR1000, `72 Z1, 2001 ZRX1200R
Nosher903
#5 PostAuthor: Nosher903 » Thu Oct 18, 2012 5:57 pm
DaveZ1A wrote:Have thought about that Chris but not sure if the guts of a new one would fit the original shells. Are they the same internally, anyone know?
I had your problem. I used the hi/lo from a repro from zed power. Went straight into the original and works.
Z1b, GPZ900R, Z40 (R.I.P), XJR1300 p u m
DaveZ1
#6 PostAuthor: DaveZ1 » Thu Oct 18, 2012 6:51 pm
kawamick wrote:Have a correct left and right hand switch stamped 3.11 for sale.
Mick
Pm or email me with the price your after Mick (a photo would be good if you could) and I will see which option is best. Cheers, Dave
Z903
#7 PostAuthor: Z903 » Fri Oct 19, 2012 7:32 am
I'm also looking for one or at least the workings of the "Pa" function. The Z-Power ones don't seem to have this either?? (US style switches).
Seems most switches around now have this flasher blocked off with a metal plate.
#8 PostAuthor: z1bman » Fri Oct 19, 2012 10:31 am
z power do sell both types the pass button is part of the horn button
Z903
#9 PostAuthor: Z903 » Fri Oct 19, 2012 12:42 pm
Nah, the early one I'm after had "Hi" "Lo" and "Pa" on the same knob. (Separate horn button) the US ones had the Hi & Lo with White lettering but the Pa is left Black, and it's locked off with the metal strip instead of the spring mechanism.
#10 PostAuthor: z1bman » Fri Oct 19, 2012 12:58 pm
#11 PostAuthor: chrisu » Fri Oct 19, 2012 2:31 pm
i refer the honourable gentleman to my original comment.........
especially at that price.
