Crankshaft Missing Nipple
cheeme
#1 PostAuthor: cheeme » Thu Oct 18, 2012 3:21 pm
HELP ..
The crank shaft from my Z1000H seems to be missing a nipple locator thingy - sorry I don't really know what to call it. The photo below is of a different shaft ..but it clearly shows a nipple right at the bottom of the photo.
The question is ..Do I need the nipple and if so any ideas about where I can get one or even if its possible to graft one on :wink:
Shaun.
'80 Z1000H, '04 BMW R1150RT
http://cheeme.weebly.com (My Restoration Project Blog Site)
#2 PostAuthor: z1bman » Thu Oct 18, 2012 3:52 pm
do you mean the roll pin that locates the timing advancer? it is still available from kawasaki part no 555A0408 PIN-SPRING,4X8 or you could try a good engineers merchants 4mm x 8mm roll pin
cheeme
#3 PostAuthor: cheeme » Thu Oct 18, 2012 5:23 pm
That's the one! thanks :D
Shaun.
#4 PostAuthor: Rich » Thu Oct 18, 2012 6:58 pm
or cut 8mm off a drill shank and use that
