26mm carbs
26mm carbs
Whos got a picture of the underneath insides of a set of 26mm carbs, mine dont seem right for some reason,
Ash, sorry no picture as yet!
What you are probably looking at is the difference in the Air/fuel screw adjustments. The later Mikuni 26mm carbs had a fuel adjustment screw at the bottom closest to the head, whereas, the earlier carbs had the short spring loaded Pilot air adjustment on the top.
Garn i will put a picture on later then you can see, not got a manual to do any references, mine should have the later 32mm cvs on them but the bike came with the 26s, theres no main jet thats for sure, and the only air screw from what i can see is on the top, little brass screws that sit offset either side of the carb bodies, i do know from the past that some of these carbs had a 1.5 or 1.7 idle jets, these dont have them either,
Garn heres some pics of my carbs, see what you make of them,
Posted: Mon Oct 15, 2012 1:30 am Post subject:
[img]http://i5.photobucket.com/albums/y190/kwakadude/IMGP0019_zps8f39e273.jpg[/img
Deff no main jets or idles jets
ash, they are 24mm 650 carbs, you were asking about 26mm carbs as fitted to Z900A4 etc
I think I might have some emulsion tubes and mains etc, pm me if you need me to check.
Thought you were doing webers?? or maybe your thinking of going to 26mm in future. I'm like jimmock, confused
btw they look to be reasonably clean inside and also they did a 22mm version with ribs on as well, but not on many models of 650
Users browsing this forum: No registered users and 1 guest
