carb setup
carb setup
Ok iv decided i might go down the route of using my inlet manifold i had made back in the eighties and bang 40mm side draft webber carbs on my zed, easy setup with an electric fuel pump, just got to make the clearencies for the carbs,
worked well on my 1000 so why not, good thing with that set up was even in top gear doing 40mph you could open the throttle and it was instant,
Seen a couple of Zeds with twin choke webbers on. Looked cool.
