starter solenoid
bunnysZ
Granny Magnet
starter solenoid
#1 PostAuthor: bunnysZ » Tue Oct 09, 2012 4:42 pm
if someone was to remove a starter solenoid from a bike (not a zed) and then forgot which wire went onto the left side and which wire went onto the right side of the solenoid and then onto the battery ,
would it matter which side you connected the cables to the solenoid :oops:
#2 PostAuthor: z1bman » Tue Oct 09, 2012 5:38 pm
wouldn't make any difference which way round they are
KeithZ1R
#3 PostAuthor: KeithZ1R » Tue Oct 09, 2012 6:29 pm
its only a switch
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
Mr Puffin
#4 PostAuthor: Mr Puffin » Wed Oct 10, 2012 8:20 am
they tend not to be marked positive negative so i would say not a problem
Garn 1
#5 PostAuthor: Garn 1 » Wed Oct 10, 2012 8:30 am
Just a thought, if you are talking about the two small leads that go in to the solenoid coil, they must have polarity as the direct current causes the centre slug to move up or down, within the coil!
The larger connections can be changed over as said before, its just a switch!
Taffus
#6 PostAuthor: Taffus » Wed Oct 10, 2012 9:33 am
(\__/)
(")_(")Image
