Hi,
The engine will be cleaned when its finisched and you will see the resold when its done and then I will tell you how I did it.
The pink stuff on the engine is glue and we always use this stuff and works fine.
A udate will follow...
PART TWO BUILDING MY Z1
- PatrickAnnbelgium
- Regular Poster
- DogsbolloxofZ1B
Blasting or paint stripping an assembled engine?
There has to be a hazard of getting the chemicals / blast media where you don't want them surely.
I hope we get some detailed pictures of how this can be pulled off.
Good luck Patrick if that is the plan.
From Mark
From Mark
- PatrickAnnbelgium
- Regular Poster
sand blast with engine closed
[/img]
thats how we do it in Belgium and its not the first that we paint like that.
The little black stuff will be removed with cleaning products.
Born to be ride....with Kawa.
Re: NEW PICS ENGINE 73
Is that a Z650 alternator cover i see hanging up on your wall Patrick
#449
Z1000A2 Z650B1
#449
Z1000A2 Z650B1
