Dear all, any help advise and piping diagrams for how to fit an oil cooler to my Z900 please.
I have picked up myself a hyabusa oil cooler rad and want to find out how I fit it, I have just rebuild my engine using some original Acorn Four race pistons and I think that it may need the oil cooler so am going for this.
any help would be greatly appreciated.
email if you like @ woody1968@gmail.com
thanks
John
how do I fit an oil cooler help please
just done this on my Z1 so pm me and i'll run you through the process and what to buy.
Zed1015 and GB were a lot of help !!!
http://z1ownersclub.co.uk/forum/viewtopic.php?t=20819&highlight=cooler
Pigford wrote:Usually, the oil pressure switch unit (located behind the barrels, under the cam chain adjuster) is replaced with a 2 x take off which is then connected to the oil cooler
http://www.debben.co.uk/acatalog/Z900.html
You would then require the hoses & fittings to suit - Debbens could provide these or you could try -
http://stores.ebay.co.uk/Torques-U-K?_t ... 4340.l2563
Wots up DOHC
