Fork Leg holding tool - Z1000R etc
martinz1000r
#1 PostAuthor: martinz1000r » Tue Aug 28, 2012 4:14 pm
anyone got the tool that you stick down the fork leg to stop the damper spinning when you trying to undo the allen bolt in the bottom of the leg. I am trying to change a stanchion. Anyone got one I can borrow? Happy to cover costs.
Either that or the recommended work around please!
#2 PostAuthor: paul doran » Tue Aug 28, 2012 4:23 pm
Martin use a brush handle
if You force it down on the damper rod it is usually sufficent to stop it spinning
martinz1000r
#3 PostAuthor: martinz1000r » Tue Aug 28, 2012 4:28 pm
paul doran wrote:Martin use a brush handle
i did wonder about that but was worried about it splintering.
#4 PostAuthor: paul doran » Tue Aug 28, 2012 4:36 pm
no it should be okay
#5 PostAuthor: chrisu » Tue Aug 28, 2012 4:38 pm
always worked ok for me..............
martinz1000r
#6 PostAuthor: martinz1000r » Tue Aug 28, 2012 4:47 pm
that worked! Just got to explain to Mrs S now why her broom has horrid black sludge all down the handle. Should have used one from the garden rather than the kitchen!!
Oops :oops:
Taffus
#7 PostAuthor: Taffus » Tue Aug 28, 2012 6:26 pm
martinz1000r wrote:that worked! Just got to explain to Mrs S now why her broom has horrid black sludge all down the handle. Should have used one from the garden rather than the kitchen!!
Oops :oops:
Tell her she needs to look after the toys you buy her........and then run like f*** :P
(\__/)
(")_(")Image
750steve
#8 PostAuthor: 750steve » Tue Aug 28, 2012 8:07 pm
Taffus wrote:Tell her she needs to look after the toys you buy her........and then run like f*** :P
:rofl :rofl :rofl :rofl
#9 PostAuthor: Ginger Bear » Tue Aug 28, 2012 8:27 pm
Martin, I'd guess by the lack of your 'on-line' presence for the last few hours that Mrs S is dealing with you right now! :smak :pok :box
:rir :rir
# 104
rodge70
#10 PostAuthor: rodge70 » Wed Aug 29, 2012 8:11 am
i use a length of m12 studding with a nut welded to the end,that way the brush handle stays clean when she needs to sweep up after me :D
martinz1000r
#11 PostAuthor: martinz1000r » Wed Aug 29, 2012 2:40 pm
Ginger Bear wrote:Martin, I'd guess by the lack of your 'on-line' presence for the last few hours that Mrs S is dealing with you right now! :smak :pok :box
:rir :rir
She hasn't noticed yet! Not sure what was worse; the smell of old oil or the Gunk i used to try and clean it up......
25 year old fork oil absolutely stinks
#12 PostAuthor: ZedHead » Wed Aug 29, 2012 4:33 pm
I had no problem from the wife when i used her broom handle .....
She could still fly on it ! :evil:
