How much should it cost to get new seats and guides fitted to a head?
Are there any benefits to getting bronze liners fitted to the existing guides?
Seats and Guides fitting - How much ?
Try Sepp at Kegworth,they will fit insert guides to your existing ones work fine,their work is always good and you can courier it to them,i got a very low miles from the states for £200 ish complete with cams etc,or you could give DK at newcastle under lyme a bell,i know guys on here berate them but their Jap engine spares room is huge,all the stuff i have had from them is fine,or put a wanted on here,waht exactly is wrong with your head?...Cheers Paul J
Cheers Paul, I problem is low comp. When i pulled the head off and poured petrol down the ports the exhaust was ok but the intake was pissing out.
I gave the head to John Wyatt, a reputable, local Jap bike restorer. He says the head needs everything. Stems, Guides, Springs, Shell bearings as well as the seats recutting, or more likely, replacing. I reckon the bits alone come to £250 ish alone.
I will follow your advise and advertise for a new head to hedge my bets.
Cheers Dave T
Cheers Dave T
- Regular Poster
How are the valve clearances? If you are having to tip the valves to get clearance you need new seats, if not just have them re-cut.
http://www.z1ownersclub.co.uk/forum/vie ... highlight=
This is not a cheap option but in my opinion it's worth spending the money, motor runs soooo much better now
Not sure about the bronze valve guide liners. I used genuine Kawasaki replacements.
